201 engine
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Topic: 201 engine
    Posted: 06 May 2020 at 3:36pm
Any one know if it is possible to use form a gasket on th oil pan of my WC? Thanks
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 4:02pm
Please do it right!
watch the video done by our late master of the oil pan Don Bradley
[TUBE]9LWCMvO_Dis[/TUBE]
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 4:31pm
get some cork gasket sheet an cut out a new one made some not hard' to do.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 4:37pm
Originally posted by JoeM(GA) JoeM(GA) wrote:
Please do it right!
    ABSOLUTELY, X2!!Forma gasket has no place on those oil pans!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 9:03pm
I'LL do it the right way. Thanks guy's I will do it like the video.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 7:02am
Yes you can, if you don't mind all the blue goo ending up clogging up your pickup screen and in turn ruining your motor.  That's why there are gaskets available for installing an oil pan.  If a job is worth doing, DO IT RIGHT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 7:13am
1947WC,
And Don would have suggested to pull the engine, if you haven't already. Its the best way to get a good fix on sealing up the bottom end of these old engines. And don't forget the F gaskets!
Farmer Amy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmer Amy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 3:42pm
Working on my late Father's WD, how do I know which gasket set?  Seems like one set has the F pieces and one the C pieces... thanks in advance!
This page was generated in 0.119 seconds.
