201 / 226 governor springs |
Gary in da UP
Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Topic: 201 / 226 governor springsPosted: 20 Jan 2010 at 3:36pm |
Taking apart an engine and the governor spring has a yellow stripe painted on it , who can tell me what rpm range this spring was intended for and what other colors did Allis use and what were their rated speeds ? Thanks, Gary
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 20 Jan 2010 at 3:42pm |
A d17 and 175 spring have blue stripe .They say they are a different shade but it takes the partnumber for me to know the dfference. I think white is a wd spring . I dont know the yellow spring so I guess it would be a wc then again someone could correct me cause I may have the white spring confussed . GLeanor spring has no stripe or slug in the center of the spring.
Allis Fields
Joined: 17 Sep 2009 Location: Reedsburg,Wisc. Points: 332 |
Posted: 20 Jan 2010 at 4:16pm |
I got grease on the new one and couldnt tell what paint color it was. I had a wd45 and a d17 new. I used the grased one because it had larger wire and a thicker plungr than the yellow strype one. If I'm rightthe yellow is for wd45 and wd/1700rpm mag.
