2000 Plow
DOlson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DOlson Quote  Post ReplyReply Direct Link To This Post Topic: 2000 Plow
    Posted: 22 Apr 2011 at 11:42pm
How bad of a job is it to replace the pivot pin bushings on the re-set stub beam on a hydraulic re-set plow and how much play is excitable?
Thank Derrick
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 11:48pm
Don't know. We never did that I remember. Maybe we just didn't need to, otherwise I would've been in the middle of it helping dad.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 6:28am
I needed some parts from one from a salvage yard one time. After beating on it with a big hammer for a while, the fellow gave up and I bought the complete assembly to keep the part I needed from getting damaged. I have a press I plan to use when I get around to it. In the mean time I occasionally squirt penetrating oil on the joints to soften things up.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 10:15am
You will need a big wrench to get the nuts loose and properly tight again.  I remember buying a 600 ft-lb torque wrench (but not the actual torque setting) when I was testing these trips.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DOlson Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 6:59pm
I have the tools just need to know is more work than its worth, plow has a lot of good parts. Or should I just use it tell its wore out
Post Options Post Options   Thanks (0) Thanks(0)   Quote DOlson Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 9:35pm
bump
This page was generated in 0.101 seconds.
