|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| 200 with 8 bolt hubs |
| Post Reply   |
| 190xt MN   Bronze Level   Joined: 15 Sep 2019 Location: Minnesota Points: 73 |  Post Options  Thanks(0)  Quote  Reply  Topic: 200 with 8 bolt hubs Posted: 08 Jan 2021 at 9:43am |
   I saw a picture of a 200 the other day that had 8 bolt front hubs. I was wondering if the cast halves that slide into the front axel housing with the spindle attached from a 210 or 220 would fit in a 200/190xt housing? Or can the entire axel assembly be interchanged? I’m looking at putting a quick tach loader on a 190xt 3, and was just curious if the heavier steering spindles were something that could be changed to make the tractor more loaded friendly. Thanks in advance for any replies!
| jiminnd   Orange Level   Joined: 16 Sep 2009 Location: Rutland ND Points: 2307 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jan 2021 at 9:45am |
   Is that was the one on U tube it had a 210 or220 front end on it, if not just disregard this comment.
| 190xt MN   Bronze Level   Joined: 15 Sep 2019 Location: Minnesota Points: 73 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jan 2021 at 9:49am |
   Yup that’s the one. So you figure it has the whole front axle assembly under it?  | |
| 190xt MN   Bronze Level   Joined: 15 Sep 2019 Location: Minnesota Points: 73 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jan 2021 at 10:12am |
   Had a side by side pic of a 220 and a 200. I see the difference! I wonder how much has to be changed to get that heavy axel under there.
| TramwayGuy   Orange Level Access   Joined: 19 Jan 2010 Location: Northern NY Points: 11781 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jan 2021 at 10:14am |
   Was it perhaps an industrial version?
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jan 2021 at 10:40am |
I've installed a 210/220 axle under a 185 and really the only serious fabrication work was the rear axle wishbone pivot pin and bracket.  I cut the front pin socket off the old axle and rewelded it to the top of the 210/220 axle. That was easy.
| HD6GTOM   Orange Level     Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jan 2021 at 4:17pm |
   They defiantly need a heavier front axle with a loader on them.
| DougG   Orange Level   Joined: 20 Sep 2009 Location: Mo Points: 8370 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jan 2021 at 6:20pm |
   Ive had a loader on a One Ninety- and 200- 6060 in my opinion- the loaders need to be matched to the tractor , too many times Ive seen a 200 - loader on it with a 7 ft bucket- thats way too big to accomplish anything except tear up a tractor, i have a 6060 with a 4 ft bucket on it and its a perfect fit, just my 2 cents, guy i used to work for had a 5050 with a 4 ft bucket and it worked great , never tore nothing up
| 190xt MN   Bronze Level   Joined: 15 Sep 2019 Location: Minnesota Points: 73 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jan 2021 at 6:49pm |
   Yeah, there’s no point in getting crazy. It’s better to match the loader to the machine. Also, and this is coming for someone who runs heavy equipment for a living, no farm tractor with a loader is a piece of construction equipment. You have to operate within the equipments limits.
| DougG   Orange Level   Joined: 20 Sep 2009 Location: Mo Points: 8370 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jan 2021 at 7:15pm |
   I hear ya 190 xt, Im on a construction site every day running a Lull and equipment- but they are made for this- other than AC farm equipment
 Edited by DougG - 08 Jan 2021 at 7:16pm | |
| GregStremel   Bronze Level   Joined: 06 Aug 2013 Points: 81 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jan 2021 at 7:25pm |
   Regarding the strength of the 190 axle, over 30 years ago we put an axle on a WD that we used ever since as a dedicated loader tractor. The rear tires are full of calcium and a cast weight is on each Side of the rear axle. The heaviest loads have been a 20 foot header for our M and a pallet of quickcrete. That weighs a little over 3,000 lbs.  We only lift these loads on level and flat ground.  The front tires squat and there is not much traction on the rear but we have had no problems all these years. We don’t need to lift the head anymore and we purchased a fork truck to lift the occasional pallet of quickcrete.  The usual load now is a seed probox (2,500#) and 5x6 round bales. | |
| 190xt MN   Bronze Level   Joined: 15 Sep 2019 Location: Minnesota Points: 73 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jan 2021 at 8:56pm |
   Well then for the little bit I will do, the stock axel will be more then enough!!
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jan 2021 at 9:45pm |
My Customer always broke spindles on the 180-200 style axle as the loader was really too large. The axle frame wasn't the weakness, the spindles were, and front wheels had to be kept TIGHT with only six bolts.
| 190xt MN   Bronze Level   Joined: 15 Sep 2019 Location: Minnesota Points: 73 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Jan 2021 at 10:15pm |
   Dr. What model of loader did that customer have?
| KJCHRIS   Orange Level     Joined: 21 Dec 2015 Location: WC Iowa Points: 966 |  Post Options  Thanks(0)  Quote  Reply  Posted: 09 Jan 2021 at 12:47am |
   I've had a Westendorf WL40 w/ 72" bucket, bale spear and pallet forks on my 200 since mid 80's. No problems, but then I don't ram n jam it around. Most recent heavy lift on it was to unload and set a 1000 gal LPG tank with gauge showing 15 - 20%. It really made the 10:00x16" tires squat, even with 40 psi in them. "HAD" fluid in rear and 2 outside wheel weights/ side, BUT replaced the bad tubes & rusty rims in Dec '20 so no more fluid.  We loaded over 1000 6 x 5 round bales 2 winters ago, that sold on an estate auction 1 mile away.  You'll Just need to remember it's a 40- 50 year old outfit AND is not a bull dozer. | |
     AC 200, CAH, AC185D bareback, AC 180D bareback,  D17 III, WF. D17 Blackbar grill, NF. D15 SFW. Case 1175 CAH, Bobcat 543B,
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
