200 series trailer disc |
farmboy59 ![]() Bronze Level ![]() ![]() Joined: 15 Mar 2016 Location: Gobles Michigan Points: 29 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Jan 2019 at 12:07pm |
I've got a 214 Allis wheel disc that I picked up a few years ago. A few of the Bal-Pak bearings have seen better days. I've heard they're obsolete, what can I replace them with? Also, one gang of disc blades are smaller than the rest, how do they come apart so I can put the correct sized blades on?
36 WC, 50 WD, 51 CA, 55 D-14, 59 D-17, 62 D-19, 73 610
mruhlig77 ![]() Orange Level ![]() Joined: 19 Aug 2014 Location: central Indiana Points: 593 |
ball-pak bearings are available used from several places....seen them a swap meets...take one of yours off to make a match....or rebuild??
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 965 |
You can look in the Knowledge Base section on this sight for a good description of parts and how to on these bearings.
I'll have to look around for them when I get into restoring my implements. Still have plenty of work to do on the tractors haha. There might be a shop in town that I could get new ones at.
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3072 |
The bearings are really an assembly and no longer available.
I wrote the knowledgebase article. Take a look at it. Sure you can pay $50-$100 for a used bearing, but I'd rather have a new one. To take a gang apart, First remove the hanger bracket bolts and drop the gang and brackets off the disk. Next take the gang axle nut off the shaft then slide the pieces off one by one. Carefully lay them so you can put them back exactly how they were. The bearings and spacers are directional so you have to put them back on correctly.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54243 |
And, like doing brakes on a car, if you only take one side apart, at a time, you always have a pattern to look at(the other side), should there be any questions on how to re-assemble...
