200 Rear Remote Problem
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Topic: 200 Rear Remote Problem
    Posted: 17 May 2019 at 6:33am
Last fall and last night while round baling hay after about three hours the door will not stay shut on the baler. I can switch sides and continue on but when I switch sides the hydraulic tie arm on the baler will drop and not stay up. I changed out the fittings on that side remote but that didn’t help. Is it a valve problem or a linkage problem? What do I need to check?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 10:02pm
The only hold to the valve is the fit of spool to valve body. Other valve must be a tighter fit. A lot of bailers had a locking valve so tractor valve didn't have to hold gate shut.      MACK
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 8:22am
It sounds like the baler door is not latching. You didn't say what brand of baler. My Vermeer and New Holland have locks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 8:36am
It’s a New Holland 846.
This page was generated in 0.336 seconds.
