200 parking brake
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 200 parking brake
    Posted: 26 May 2021 at 6:49pm
Hello everyone.
I seem to remember a post on that topic but I couldn’t find it. Anyone remember it and can find it, I’m sure there’s more then one.
Thanks
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 8:47pm
What's your question/ailment with your 200 ?
btred1466 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote btred1466 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 9:54pm
Is this what you are trying to find?
https://www.allischalmers.com/forum/topic178061.html
I saved the topic.
Edited by btred1466 - 27 May 2021 at 10:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 10:32am
that was one of them thanks.
the other day something went wrong lol. It won’t release now. Couldn’t remember if any post mentioned that issue.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 11:50am
Do you have one wheel that locked up when you hit the brakes or is the parking brake just not releasing? It could be as simple as a roll pin in your linkage or you could have a spring broken inside the brake or a lining coming apart and doubling up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 7:50am
just the left brake pedal won’t come back up. Luckily didn’t push all the way and isn’t engaged. It appears the lever is still turning its  little shaft
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 10:05am
I'd say the linkage behind the lever is frozen and rusted. I had a 200 years ago at the dealership where I worked and it had that issue. Had to get in by taking the rear side hood off and taking the linkage apart or oiling it up, can't quite remember as it has been 25 years ago.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 6:16pm
I think just from memory there should be a spring behind the dash to lift the pedal up. Can you pull it back up with your foot or hand? Maybe the pivot shaft for the pedal is rusty, spray some lube on it.
