200 injection pump
alc609 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alc609 Quote  Post ReplyReply Direct Link To This Post Topic: 200 injection pump
    Posted: 10 Nov 2016 at 11:59pm
When pulling injector pump, do you line up two small timing lines behind the inspection plate on side of pump? Or is there anything else to line up? There is cap nut out in front of pump on the block, is there anything to look for there? Thanks
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 5:27am
Set the timing per manual for #1 cylinder which should line up the marks on your pump.
I then just removed mine. Take note when you pull it off, the "Dot" on the pump side slot and on the drive shaft as they line up also.
Charlie
This page was generated in 0.361 seconds.
