200 hard getting into reverse
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: 200 hard getting into reverse
    Posted: 30 Nov 2019 at 7:18pm
It acts like the stubby shift lever back under the cover where you check trans and hyd oil doesn't move far enough to the right to easily slide into reverse. When shifting I have to nudge that little lever to the right with my foot then it shifts easily. I've owned this tractor for 2 or 3 years and it's been like that since I bought it.
If I remove the long cover over the shift linkage, that allows the long shift lever more travel and then it shifts without problem. Was thinking tonight maybe it's dry in the socket?
I could video this if needed.
Wink
I am a Russian Bot
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2019 at 7:54pm
With the cover off rock the shifter left to right and back watch the joints you’ll figure out where the slack is , my bolts were wore all I needed was new bolts
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2019 at 8:17pm
Tighten each of the yoke bolts until they are too tight and then back them off until it shifts easy. Oil each joint too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 11:11am
Like was said , linkage adjusments and worn bolts usually is the problems,, the socket ball assembly is available thru Mc master carr ,,
