200 Camshaft gas vs diesel
WLHD21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WLHD21 Quote  Post ReplyReply Direct Link To This Post Topic: 200 Camshaft gas vs diesel
    Posted: 13 Feb 2020 at 7:37am
I am working on 200 that has cupped lifters and cam lobes that vary by 0.035”, I have a 301 gas from gleaner G. Before I tear it down does anyone know if there different, I would assume they are, but I’ll ask the experts. Thanks ,
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 7:46am
I would think the valve opening and closing events would be different from a gas to diesel. A quick look on agco parts books shows they are different part numbers, but don't know exactly what is different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 7:48am
The gas camshaft surely doesn't have the 4 inch long bolt in the nose to prevent camshaft breaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 10:18pm
My D17D has a gas cam in it. Sounds like you better find the exact cam like Dr A is talking about though.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2020 at 7:30am
I have heard of guys putting 262 gas cam in 262D, making them run better.      MACK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2020 at 6:17pm
They will interchange - but you are going backward - the gas cam on the intake only had a lift of .355  whereas the diesel was .4405  exhaust was about the same - I can't find the specs now but the gas timing and duration  was a few degrees different.  They were ground out of the same casting.
The 2000 gas engineering had economy as an objective , the  2500 265 was the cubic inch amount  in gas version to match the diesel in hp but the low #'s were a killer in cost for pistons sleeves and cranks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WLHD21 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2020 at 10:53pm
Did the 301 gas engines in the XT’s have the bolt in the cam shaft?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2020 at 6:54am
301 gas cam never had a bolt in the end.          MACK
