200 Cab |
Red Bank ![]() Orange Level Access ![]() Joined: 18 Apr 2018 Location: Germanton NC Points: 1051 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Jul 2018 at 11:36am |
Posted ad in classifieds looking for a cab for a 200 and have had several good responses but the topic of what cabs fit has come up and I was wondering if anyone knew what would work and what all will I need as far as brackets, etc. Calvin has a Laporte cab off of a 210 or 220 I can't remember and Gary has a cab off of a 190xt and allisrutledge has a year round cab.
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29792 |
Any cab that came off an XT should fit. The LaPorte 210/220 cab just needs a few different pieces but is overall the same cab as what came with the 200 from factory.
Wink I am a Russian Bot |
Are the pieces needed something that could be fabricated easily or would I need to locate the right ones?
I would guess that you could fab up just about every part needed but I do not own a 210 or 220 to verify. I do have a 200 with factory cab.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8322 |
Id be caucious and get a cab right off the tractor and with the right mounts, etc,, it can turn into a headache quick
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6368 |
Probably a bit far from you, but Greens has a Factory cab or two on 200's
1 was missing a lot of the windows though.
Charlie
Charlie do they have pictures of the cabs on the internet somewhere?
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34291 |
Redbank, If you got a piece of equipment you have to go to the right side of it often, It gets dam old fast crawling out the left door and walking around to the far side and back again. I have threatened to cut the welds on the right side and fab a door in on the AC cab on the one 200 I have. The other 200 has the Year Around, and all my 190 and XT's have 2 doors and can get in and out on either side. Don't like them single door ones, not even on the thousand series.
No, you can call them and they will send you one with a quote. It's a huge salvage yard, stuff piled on top of stuff...
Charlie
JC thanks for the advice I have never had a cab tractor and I am concerned about how claustrophobic I am going to feel anyway.
Charlie- thanks I will give them a call. |
Any of the ones I saw will need repair/refurb. If you want all the A/C and heat items, you need to ask about that.
Charlie
The 200 factory cab is ROPS rated I do believe.
Not sure if a year-round would be.
Charlie
The 190 cab is just a coffin if you roll it. Plus you would only have a fan. I have never seen the A/C option.
Charlie
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21763 |
A factory (LaPorte built) AC 200 cab was quite roomy and pretty darn quiet. Now, after 40+ years, I'm sure the sound deadening insulation isn't like it used to be. Compared to a Hiniker or Year-a-Round cab it was very nice.
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3516 |
Here are 3 photos from a May 1973 AC 200 sales brochure. First photo shows tractor chopping corn. Second photo talks about cab's rubber mounts (was a huge improvement to isolate operator from incoming engine/rear-end frame noises) & other comforts. Third photo list specifications . The optional equipment is listed on the right side with cab (ROPS) info in it's lower right corner.
I feel the 200's factory cab with it's door shape and front glass with lower viewing windows may have been the predecessor to the black belly 7000 series?? Anyone on this forum that used to work at AC factory want to weigh in with their insights?
