1960 Roto-baler with Overdrive
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2025 at 8:43am
Interesting. The serial number on this one is 74430, no C visible... But I hadn't ever heard about the factory possibly reworking ones they had and putting different SNs on them until now.
What makes the axle a Number 10 vs. just a later production normal Roto-baler axle?
And where should I be looking at for the pick up feet difference?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2025 at 8:34am
Drp asked me to post these pictures.
#10 shoe
Usually an tell a conversion because the gearbox still has pulley for second conveyor
Regular axle
#10 axle
Edited by Mikez - 03 Mar 2025 at 8:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2025 at 6:28pm
Mikez and dr p, thank you. I had to go out and look at both of my balers again to see the pickup feet difference but I do see it now.
I wrongly assumed the axle was a later production Roto-baler thing, but now that I look at pictures of some later non-overdrive balers, I see they don't have the two square tubes for the stub axles to bolt into. The front square tube position must have been for better balancing the #10's additional weight up front from the extra conveyor?
I have learned a lot from all of you wise folks on the forum. JimIA, the twine knot theory for the dented roof also makes sense. I wonder if I can pop it back up with a little effort.
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 9:24pm
You are correct about the different axle location, it was a helper for balance with the extra conveyor.
As far as the roof, I am not sure how well it will pop out.  That era of equipment was built with very good quality iron so it is plenty thick and strong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2025 at 11:07pm
Thanks for confirming the axle positions. My thinking on the roof is to put a 4x4 post on a jack, take it slow, and see if the roof will pop up any. You may be right and it won't want to go back very well.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 6:19am
Have you tried to turn it over yet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 9:48pm
Not yet. I have been focusing on the combine but did spend the evening getting another WD-45 running. I need to unwrap a bunch of twine from the rollers, grease everything, and see what will spin by hand.
Guess I just have to hope my gearbox is okay?
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 6:19am
One of those ones you just rescued. NICE!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2025 at 7:34pm
I did turn the PTO shaft by hand the other day and it was stiff, but the conveyer chains moved a few inches so the driveline seems to be okay. Everything needs lubed up but I was happy it moved. Hopefully that means it just needs those belts put on, springs, a knife, twine, and some TLC and learning.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2025 at 8:58pm
That is so funny, grasshopper
