1960 Roto-baler with Overdrive
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2025 at 8:43am
Interesting. The serial number on this one is 74430, no C visible... But I hadn't ever heard about the factory possibly reworking ones they had and putting different SNs on them until now.
What makes the axle a Number 10 vs. just a later production normal Roto-baler axle?
And where should I be looking at for the pick up feet difference?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2025 at 8:34am
Drp asked me to post these pictures.
#10 shoe
Usually an tell a conversion because the gearbox still has pulley for second conveyor
Regular axle
#10 axle
Edited by Mikez - 03 Mar 2025 at 8:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2025 at 6:28pm
Mikez and dr p, thank you. I had to go out and look at both of my balers again to see the pickup feet difference but I do see it now.
I wrongly assumed the axle was a later production Roto-baler thing, but now that I look at pictures of some later non-overdrive balers, I see they don't have the two square tubes for the stub axles to bolt into. The front square tube position must have been for better balancing the #10's additional weight up front from the extra conveyor?
I have learned a lot from all of you wise folks on the forum. JimIA, the twine knot theory for the dented roof also makes sense. I wonder if I can pop it back up with a little effort.
