1960 Roto-baler with Overdrive
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: 1960 Roto-baler with Overdrive
    Posted: 04 Feb 2025 at 7:47pm
I found a slightly better candidate for fixing up than the $50 Roto-baler I bought last year. This one is a 1960 white top with overdrive.
The roof is slightly bowed in from someone probably storing something on top of it, and the safety shields over the intake are missing. Otherwise it seems to be in good shape and has spent most of its life inside. I am going to have to break down and get belts for it - they didn't look bad from the ad, but the lowers are delaminating.
I must be nuts to put $800 worth of belts onto a baler so I can bale and hopefully sell $100 of straw this year?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2025 at 8:20pm
You'd only be crazy if you try to transition it into something else, other than what it IS...Wink
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 5:27am
They actually made fewer white tops with overdrive than number 10's. I have some barely used spliced bales if you need some
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 6:51pm
That is an interesting point - supposedly 750 white tops with overdrive, vs. 1500 #10s? Of course, an unconverted #10 would still be much rarer. I'll send over a PM about belts.
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2025 at 10:27pm
and the over drive does?
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 6 minutes ago at 6:33pm
Overdrive?  Also, my question, been around them but they were "not overdrive".
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 46 minutes ago at 7:53pm
Isn't that the Reversing Gear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 20 minutes ago at 9:19pm
It kicks in to increase the speed during the twine wrapping cycle, then kicks back out when ejecting the bale. It just sped up the wrapping by a few seconds. I'm pretty sure I've seen a video of one in the field on YouTube but I'm not sure I could find it again. They talk about it briefly during the Roto-baler history walk at the Orange Spectacular:
Edited by wjohn - 4 hours 20 minutes ago at 9:19pm
This page was generated in 0.110 seconds.
