1960 Roto-baler with Overdrive |
Page <12 |
wjohn
Posted: 01 Mar 2025 at 8:43am |
Interesting. The serial number on this one is 74430, no C visible... But I hadn't ever heard about the factory possibly reworking ones they had and putting different SNs on them until now.
What makes the axle a Number 10 vs. just a later production normal Roto-baler axle? And where should I be looking at for the pick up feet difference?
Mikez
Posted: 03 Mar 2025 at 8:34am |
Drp asked me to post these pictures. #10 shoe ![]() Usually an tell a conversion because the gearbox still has pulley for second conveyor ![]() Regular axle ![]() #10 axle ![]() Edited by Mikez - 03 Mar 2025 at 8:38am |
wjohn
Posted: 03 Mar 2025 at 6:28pm |
Mikez and dr p, thank you. I had to go out and look at both of my balers again to see the pickup feet difference but I do see it now.
I wrongly assumed the axle was a later production Roto-baler thing, but now that I look at pictures of some later non-overdrive balers, I see they don't have the two square tubes for the stub axles to bolt into. The front square tube position must have been for better balancing the #10's additional weight up front from the extra conveyor? I have learned a lot from all of you wise folks on the forum. JimIA, the twine knot theory for the dented roof also makes sense. I wonder if I can pop it back up with a little effort. |
JimIA
Joined: 12 Sep 2009 Location: Castalia Iowa Points: 1983 |
Posted: 13 Mar 2025 at 9:24pm |
You are correct about the different axle location, it was a helper for balance with the extra conveyor.
As far as the roof, I am not sure how well it will pop out. That era of equipment was built with very good quality iron so it is plenty thick and strong. |
wjohn
Posted: 17 Mar 2025 at 11:07pm |
Thanks for confirming the axle positions. My thinking on the roof is to put a 4x4 post on a jack, take it slow, and see if the roof will pop up any. You may be right and it won't want to go back very well.
dr p
Joined: 24 Feb 2019 Location: new york Points: 1406 |
Posted: 18 Mar 2025 at 6:19am |
Have you tried to turn it over yet?
wjohn
Posted: 18 Mar 2025 at 9:48pm |
Not yet. I have been focusing on the combine but did spend the evening getting another WD-45 running. I need to unwrap a bunch of twine from the rollers, grease everything, and see what will spin by hand. Guess I just have to hope my gearbox is okay?
dr p
Posted: 19 Mar 2025 at 6:19am |
One of those ones you just rescued. NICE!
wjohn
Posted: 03 Apr 2025 at 7:34pm |
I did turn the PTO shaft by hand the other day and it was stiff, but the conveyer chains moved a few inches so the driveline seems to be okay. Everything needs lubed up but I was happy it moved. Hopefully that means it just needs those belts put on, springs, a knife, twine, and some TLC and learning.
dr p
Posted: 04 Apr 2025 at 8:58pm |
That is so funny, grasshopper
WD45
Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 956 |
Posted: 07 Apr 2025 at 9:02pm |
I just ran our WD WIDE OPEN and the bales tied quickly.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
dr p
Posted: 08 Apr 2025 at 5:33am |
That is fantastic! You might want to write this day on a calendar
Page <12 |
