1958 HD-5G into the fold: |
Page <12 |
Codger
Thanks(1)
Posted: 11 Jan 2026 at 7:42pm |
Received alternator as updated schedule showed. Nice unit I'll get installed tomorrow if another order of blasting consumables shows up.
Seen this and it's an interesting watch: |
That's All Folks!
Codger
Posted: 13 Jan 2026 at 7:18pm |
Talked to starter rebuilder this afternoon and not going any further with the 30MT. He also recommends a 39MT to replace this one. Didn't have one but will build one up from parts for me. Less $$$ to go with the 39MT too as two of the field coils of the original starter were out of spec, and one pole shoe was cracked/busted from the starter motor being waylaid with a hammer several times. There are actually dents beat into the housing. Also discovered the cylinder block in the tractor is aluminum. Head, and flywheel housing are iron, but most everything else is aluminum.
Received blasting order today late in the afternoon so back at it tomorrow to finish up.
That's All Folks!
Les Kerf
Posted: 14 Jan 2026 at 8:27am |
Interesting!
Codger
Posted: 14 Jan 2026 at 9:47am |
Surprised me. I've seen many 3-53 Detroit engines in both iron and aluminum when in the military but this is the first civilian aluminum block I've seen. However, I don't know much history on the tractor. It was very near dark when I was pulling the starter and a magnetic work lamp wouldn't stick to the block is how I found it before looking closer and snapping photos.
That's All Folks!
Les Kerf
Posted: 14 Jan 2026 at 2:11pm |
Cool! A 'lightweight' HD5G
Codger
Thanks(1)
Posted: 14 Jan 2026 at 3:41pm |
This engine is in a Clark backhoe loader but may go into that HD5G if the 2-71 is not good. I'd like to fashion a clamshell bucket, (or tines) for the HD5G as have a lot of brush and trees to take out at some family property. I have about 1/3rd of a rake built for the 11B and once all the relatively "heavy" groundwork is done, I'd like to leave this HD5G at the property for maintenance of the place. The TLB is shot but the Detroit engine runs well and the hydraulics are very strong. It came along to me in a trade when the former owner traded both the 11B, and this backhoe in on a new mid sized excavator. ![]() |
That's All Folks!
Codger
Posted: 16 Jan 2026 at 7:23am |
Going to pick up the freshly built/rebuilt 39MT starter this afternoon. Basically an older case with everything new inside. Wanting to get this old TLB out of where it's at and back to the shop for further evaluation; but the power shuttle seems to be worn out. Fine cold but as it warms, begins to slip and the tractor won't pull itself unless in low gear. Not much use pushing into a pile this way at all......
That's All Folks!
Codger
Posted: 17 Jan 2026 at 6:12am |
What a circus. Rebuilder did a nice job building up a new starter but installed 24VDC field coils instead of 12VDC and won't work in the application. Too late in the day when I arrived to correct so will be addressed the first of the week. Forecast is very cold for the next few days so no real loss of time.
Edited by Codger - 17 Jan 2026 at 6:12am |
That's All Folks!
Les Kerf
Posted: 17 Jan 2026 at 7:57am |
Bummer :-(
Codger
Thanks(1)
Posted: 17 Jan 2026 at 8:21am |
Yep, we were talking about the 11B, and my large DD powered air compressor (which are both 24VDC) along with this tractor and the conversation got convoluted. All starters use the same SAE #3 mount, are CW rotation, but use different drives to intermesh in the ring gears. All straightened out now so will be corrected Monday. Tuesday is supposed to reach back into the 30's so will hopefully install then.
That's All Folks!
Codger
Posted: 6 hours 31 minutes ago at 9:37am |
Got a call and starter is rebuit to 12VDC but it's one degree here now and going to remain cold today so probably not even going out of the house.....
That's All Folks!
Les Kerf
Posted: 4 hours 8 minutes ago at 12:00pm |
Good plan!
Page <12 |
