1951 Model D Grader |
wn willis
Topic: 1951 Model D GraderPosted: 06 Dec 2019 at 1:06pm |
Still looking for a creeper gear for my Model D Grader.
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 14 Dec 2019 at 1:30pm |
My D is also a 51,--no creeper in it either. I have been told that finding one is totally out of the question, sad but dont think many of them ever came out with creeper since it was a option. Good luck on your search! -- still passing the word, ( not gonna put one in mine!)
wn willis
Posted: 15 Dec 2019 at 4:27pm |
I probably won`t find one either. Have a current problem that I have not been able to solve; engine is misfiring. I changed plugs, wires, points. Checked timing, everything I can think to do, Still no joy. Number 1 plug gets heavy carbon. Even installed a new distributor, thought the cap might be cracked. Adjusted the carb, still nothing. Any ideas? The engine is a 1955 A/C 4 cyl WD 45 Ser.# 211549 I have a power unit engine (W226) that I am thing of getting rebuilt and install it in the grader. My grader serial number is D 1514.
Edited by wn willis - 15 Dec 2019 at 4:35pm |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35638 |
Posted: 15 Dec 2019 at 4:40pm |
Run a compression check, then with piston at TDC with valves closed put a little air to that cylinder and find where it comes out. Burnt valve, bad intake leak, bad rings? All possibles
Edited by DMiller - 15 Dec 2019 at 4:40pm |
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Posted: 15 Dec 2019 at 5:02pm |
We had a problem with our D after we had restored it. Running, missing, etc. I removed all of the new wires and coil and used the old ones and it runs fine now. Don't trust new offshore parts.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025, |
DonBC
Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 947 |
Posted: 15 Dec 2019 at 6:06pm |
My D grader would foul #4 plug at times. Compression was not great so I took the head off. Valves were bad. Got the head fixed up and the compression improved a lot but when the head was off the ridge around the top of the sleeve suggested the rings and sleeve work could help as well. #4 sleeve had a scratch in it that could suggest a broken ring but I never did do an over haul. After I installed electronic ignition, the hotter spark seemed to keep #4 clear.
ac fleet
Posted: 31 Dec 2019 at 2:16pm |
Mine fouls the plugs too. I just assume that the engine is worn out. It has had a ruff life with no care or service work done to it. ---- mine starts hard too, low compression is probably the reason for that. It moves a lot of dirt for being a little guy and I don't crowd it. we take small bites and make extra passes.
