1950 B governor weights/pins |
cdsloop ![]() Bronze Level ![]() ![]() Joined: 09 May 2017 Location: North Carolina Points: 20 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Mar 2020 at 11:57pm |
I'm continuing to work on refurbishing my 1950 B. It's currently in a state of disassembly, and I am working on miscellaneous things while my machinist cousin repairs the manifold. The pivot shaft for the throttle was frozen, so I removed the governor cover to get it freed up, which was successful. With the cover off, I discovered that the pins for the weights are severely worn. The pivot hole in the gear seems ok. Is there anyone that offers just the pins and weights, or just the pins? I'm trying to keep this on a shoestring budget. I see several vendors offer the pins and weights separately for the D series, but none seem to do that for the B/C, only complete governor assemblies. Can someone point me in the right direction? Thanks.
Your Agco dealer should have them. MACK
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
The shop manual might help:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf Gerald J. |
Albert ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: NW MO Points: 410 |
PM sent we can help you out
