1947 C zenith carb.
ksulkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksulkey Quote  Post ReplyReply Direct Link To This Post Topic: 1947 C zenith carb.
    Posted: 05 Mar 2011 at 4:54pm
1947 A/C C.
Can someone, please tell me the starting points on the main & low jets for a Zenith carb. number. 9705? The timing is on, good gas, cleaned the carb., volts good from the key out, but it will run okay for 2-5 min. then shut down and restart right backup but only run 2-5 mins. I can't keep it running!!!
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 5:20pm
Check vent in gas cap first,gas flow to float bowl....then float and needle. Then  air filter  system from cap on hood all the way to to choke .  I have seen a bum  coil  do this too .
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 5:46pm
  Hello Ksulkey!!  open the drain under the carb, let it run for 10 seconds it should have full flow.  If not get a coffee type can,  3/8" pipe plug, a piece of fine woven wire, roll it to look like a cigarette,  remove the sediment bowl assy, with can in place, install the pipe plug in tank, this should be done with fuel in tank which should clean crud from around opening, clean the sediment assy,  install the screen in the inlet, bend the top to close reinstall. I would recommend doing this with caution, the gas can be poured back into tank, except for crud,  Good luck    Please re post your findings.
