1942 HD-3
larslog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote larslog Quote  Post ReplyReply Direct Link To This Post Topic: 1942 HD-3
    Posted: 16 Apr 2016 at 12:00am
Looking for rollers and front idlers for a 1942 HD-3.
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2016 at 7:28am
If you don't find any close to you there a minonite family called Zimmermans in versailes Missouri. Has a big salvage yard of dozers. etc. DO A SEARCH on the net. He does ship. Not cheap but they seem to know what there talking about. norm
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2016 at 3:25pm
I'm pretty sure the 1942  HD-3 used the same undercarriage as the Model M and should be fairly easily obtained !!  Good luck with Your Rare Crawler !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote larslog Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 12:22am
When I bought it I thought M undercarriage would fit but they are very different.The roller shells are same size but the shaft,seals and mounts are different and the front idlers have an internal spring with a yoke connected to idler slides, where the M has external springs to the idler. The owner was in the process of restoring it when he passed away.It was sold at auction and I purchased it from the guy who bought it.By that time a scrapper had cleaned up any metal left at the auction site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 3:47pm
AC did not build very many, and parts sadly will reflect that...  What You have looks great...  Good luck on it..
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 7:42pm
Is it possible that HD5 parts would interchange? Hope you can find parts you need, as that rare crawler needs to have new life breathed into it. It sure looks good so far. Good Luck! Darrel
donoman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 8:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 8:55pm
how does the track pitch compare with HD5/6?
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 7:27am
There is a place in Idaho called general gear that has lots of crawler parts. I'd sure try them. If you can't find a number for them by go ogling it, let me know, and I'll get it for you. Darrel
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 10:00am
Is the powertrain pictured all that you have? I sure hope you can find what you need.
You might call Tony Carbaugh. His contact info is listed here on the site.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 12:37pm
Very neat indeed! I wonder how many of them are accounted for? It's disturbing when a scrapper comes in and simply takes "junk" to the scrap yard. There's a good chance the parts needed were in that pile! Having the pieces, even if worn out, can be repaired/saved, but not having any of it will definitely make it a challenge! Thanks for sharing!
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 9:33pm
+1 on General Gear! They supplied me with a brand new pressure plate for my HD5B. They have several machines they are parting out.
This page was generated in 0.789 seconds.
