190xt
cb550 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cb550 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt
    Posted: 09 Nov 2014 at 9:39am
Was told you can get a delete coupler or shaft to eliminate the PD on a 190xt. Where can I get these, how do they work? Any info would be greatly appreciated...thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2014 at 9:47am
There are two ways to go. One is a simple coupler that leaves you with four speeds....2nd-4th-6th-8th. I make a sliding coupler that leaves you with all eight speeds. I suppose I could also make another coupler that would provide 1st-3rd-5th-7th. (I guess that makes three ways to go).
Post Options Post Options   Thanks (0) Thanks(0)   Quote cb550 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2014 at 10:00am
Thanks for the reply. Would be interested in the sliding coupler...greater selection of speeds would be better depending on track conditions. Could you tell more a bit more about it? Do u slide it with a shifter, or is there more involved than that?
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2014 at 11:09am
Interested in knowing more about this as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2014 at 12:25pm
Shift lever under the platform usually. I have seen it made up thru the platform too.
TeamAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TeamAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2014 at 8:05pm
Dr. Allis, I need your phone #, have a friend that is interested in the shifter for a 185.
Thanks
acwd45di View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwd45di Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2014 at 1:06pm
Dr allis could you email me i would like to talk to you more about this modd as im currently building a xt puller acwd45di@yahoo.com thanks i apreciate it
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2014 at 10:46pm
We have used the manual PTO leaver, linkage and home made shifting fork on the 180 so you can switch the 2speed from the seat
This page was generated in 0.180 seconds.
