190XT
cbt1124 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbt1124 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT
    Posted: 06 Apr 2012 at 8:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbt1124 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 8:32pm
We have water running out the PTO shaft, both hydraulics and tranny have emulsified oil in their sumps.Tractor was loaned to another farmer for the past 4 years and never seen the inside of a barn. What is the best way to rid the entire systems of the bad fluid without spending a fortune on hydraulic fluid and UTF?
mtanut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mtanut Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 9:16pm
For what its worth, oil is cheap compared to a hydraulic pump replacement or a rear end rebuild. Just my .02.
I have a 185 Allis, 6060 Allis, Model K gleaner, SMTA ferg 35, ferg 20 (paps first tractor, Allis B (wife's)John Deere 240 skid loader and a bunch of the usual farm stuff.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 10:33pm
Listen to mtanut.  $200 For oil and filters versus $2000+ for transmission.  Do the math.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 7:58am
What would the rest of you guys think of using diesel to flush through the system first, just to get a rinse before running the oils through it?
I've heard of doing that to an engine that has had water in the oil and coated the insides of it is why I ask about this application.
Just a thought about a possible solution.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 8:41am
 After sitting overnite, pull each drain plug and drain the water that is there and when oil comes out replace the plug. Overfill it with diesel fuel by quite a bit and drive it around to wash her out on the inside and drain it quickly........I'd add a couple gallons to the hydraulics and probably three or four gallons in the trans.
