190XT |
cbt1124 ![]() Bronze Level ![]() ![]() Joined: 10 Sep 2010 Location: New York Points: 16 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Apr 2012 at 8:27pm |
We have water running out the PTO shaft, both hydraulics and tranny have emulsified oil in their sumps.Tractor was loaned to another farmer for the past 4 years and never seen the inside of a barn. What is the best way to rid the entire systems of the bad fluid without spending a fortune on hydraulic fluid and UTF?
mtanut ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: sandy lake, pa Points: 545 |
For what its worth, oil is cheap compared to a hydraulic pump replacement or a rear end rebuild. Just my .02.
I have a 185 Allis, 6060 Allis, Model K gleaner, SMTA ferg 35, ferg 20 (paps first tractor, Allis B (wife's)John Deere 240 skid loader and a bunch of the usual farm stuff.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7496 |
Listen to mtanut. $200 For oil and filters versus $2000+ for transmission. Do the math.
Jim Hancock ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: EL Reno, Ok. Points: 1112 |
What would the rest of you guys think of using diesel to flush through the system first, just to get a rinse before running the oils through it?
I've heard of doing that to an engine that has had water in the oil and coated the insides of it is why I ask about this application. Just a thought about a possible solution.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21852 |
After sitting overnite, pull each drain plug and drain the water that is there and when oil comes out replace the plug. Overfill it with diesel fuel by quite a bit and drive it around to wash her out on the inside and drain it quickly........I'd add a couple gallons to the hydraulics and probably three or four gallons in the trans.
