190xt won't lift disc mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 4:31pm
Settle down boys, it's Friday, and approaching "beer thirty" . . . .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 5:17pm
I like Tim's thinking! A lot!
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 8:06pm
Originally posted by allis/cattle allis/cattle wrote:
where is this flow divider???
The flow divider is on the back of the pump.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 8:54pm
Well, I've read this whole thing up to this point. Doc. I don't know how old you are but I think we're about the same age. Good to see you still have some fire left, and like myself sometimes these young squirts can get us going, but I tell you I don't believe it's hardly worth the effort anymore. As for the young fellow I think he speaks from frustration and a lack of understanding of what he's messing with, buut to give him credit at least he's trying. Many times our tongue goes in  gear before our brain does and that can cause a heck of a clash. Now from my perspective young man don't give up for what you learn will be with you forever, but I do think an apology is in order which no one has suggested yet. And Doc. could you accept it and not kick the dog? There is not enough life left to not enjoy it. Leon R  Cmo
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 9:18pm
Just to clarify, we're talking about a 3 point mounted, folding disc mower and not a drawbar mounted machine correct? This was my assumption when I said you might be over loading a little. Someone earlier made a comment about a 12 foot mower which has to be drawbar mounted and raised with a remote so I just want to clarify which machine we're discussing.
timr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timr Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 9:56pm
I realized a long time ago that people who are direct have some of the best solutions so I should listen and not not get offended by the way it's stated. They just tell you what works without alot of sugar coating.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2016 at 6:05am
Doc and a few others have always been very direct. Think of it like this....... When I go to my physical doctor and he chews my ass for doing something stupid, well I may be offended at first but in the end he's right.
It was pure ignorance, and I don't mean that as a nasty comment, that you turned up the relief pressure without putting a gauge on first. You'll end up splitting your pump or splitting the new pump if you forget it was messed with. Myself, and maybe it's just me, but I don't think anyone needs to apologize. Just move on and get the problem figured out.
There is a lot of ignorance out there, sometimes with myself too. I've talked to more than one person who had overhauled their own engine. They got the brand new kit. Slapped it in. Did no checks on clearances. Didn't even bother to thoroughly wash each piston and sleeve and give them the white glove treatment before going in. I just don't even bother telling them because it's too late and the damage is done. Now if I talk to them again and they wonder why it smokes like a freight train two years later I ask them what preparation they did to the kit before installation. They'll say .......what do you mean? That's why there are professionals who in the long run will save you money. It's alright to learn but not so much when you need to go right now.
Heck I built my own waterway once. Only once then when we hired a guy this spring to redo what I and Dad did, well you wonder, for the money why did we waste our time. We caused washouts that weren't there before....... yada yada yada.......... anyway, you get the drift.
Wink
I am a Russian Bot
jdodds79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2016 at 11:44am
Ok got the gauge on the remotes and there is 600psi on all remote hook ups.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2016 at 12:03pm
With engine running above 1800 RPM, there should be 2,200 to 2,400 psi while you hold a lever fully engaged, making the hydraulics work. If your power steering seems normal, I'd suspect the relief valve has failed on the hydraulic stack. You could swap the Traction Booster relief cartridge (front of valve stack and easy to access) for the main relief cartridge(rear of valve stack and miserable to access) and adjust it up to correct pressure spec for a quick fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2016 at 12:10pm
When you say valve stack, is that where the spools are located? Im not familiar with the traction booster relief cartridge or the main relief cartridge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2016 at 12:15pm
I may have found the culprit. On the first piece of the stack, the valve that has the acorn nut with the adjustment screw under it, there is an arm that is supposed to sit against the valve on the back side. That arm is flipped down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2016 at 12:35pm
Ok i put that arm back where it went, backed the relief valve screw back off to where i started at, ran it up to 2000 rpms, and im at 1000psi. I need to figure out exactly what and where the cartridges are and ill switch them
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2016 at 12:45pm
How far is the plunger supposed to stick out the back of the relief valve? Mine is sticking out about 1 1/2 in.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2016 at 2:45pm
It would be worth your while to order a 190 service manual. It would explain most of how the pump works and the guys on here could supplement that information.
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2016 at 2:53pm
Maybe a good point, never had a 190XT, just the 185 and 175 and down.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2016 at 3:46pm
A pic
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2016 at 3:47pm
another
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2016 at 3:55pm
So to do what drallis said, do i remove the large nut on the lift system relief valve and swap the guts with the traction booster relief valve?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2016 at 4:28pm
I switched the cartridges, no change
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2016 at 9:54pm
The linkage you are talking about has nothing to do with relief valve.
If you switched the guts, it is hard to tell where you are.
I would suggest you get some one with a flow rater to check the system out before you blow the side out of pump, then it will big $$$$$$.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2016 at 8:53am
The relief cartridge is always where to start repairs, as it is easy and inexpensive to rebuild. Usually the Traction Booster cartridge is good, as it isn't used as much as the main relief valve, so it can be used for testing. I always install a new seal kit in an existing cartridge to rebuild it. After that, if the rebuilt cartridge won't adjust to proper pressure, the hydraulic pump is the next logical component to explore. You tractor is of the age it should be a triple stacked pump, with one section devoted to lifting the hitch and implements. Good cartridge?? then there must be an internal pump problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2016 at 8:57am
It dawned on me a bit ago that once i switched the cartridges i never adjusted the pressure on the cartridge that is now in the main relief. Assuming the cartridge would be set lower coming from the traction booster side. Should i adjust pressure while monitoring gauge?
Edited by jdodds79 - 09 Jun 2016 at 8:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2016 at 9:17am
Traction Booster cartridge isn't that much lower....only about 2,000 to 2,100 psi. Should try to adjust it anyway, just to see what happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2016 at 10:07am
If you change the relief setting 1/2 turn or 1 turn (or whatever) with no results, you'd better return the cartridge back where it was or it will be too HIGH when the pump gets repaired, and split the pump wide open.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2016 at 10:42am
I went a full turn in, no change. I moved back out. I have a guy coming today to work on a baler, he is also an allis mechanic so im going to have him check it out. Thanks for all the help. Ill let you guys know what ends up being the problem.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2016 at 11:01am
For the members reference, can someone name some shops who could repair that valve,
and/or similar valves?  The shop must have the technical skill, be priced fair, and be able to get to it quickly. I am not saying THAT valve needs any service, just a general question.
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2016 at 11:12am
Any AGCO Dealership that used to be an Allis-Chalmers Dealership, probably has a seal kit for the relief valve on hand, and in 30 minutes or less could reseal it and adjust the pressure setting using another tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2016 at 12:20pm
I was thinking a valve that is slightly corroded, spring loaded spools stuck.
They would have the judgement to cleanup polish and reuse, get a new part, hone some bores and such. And have a good selection of o-rings. That alone would drive me nuts, finding good substitute o-rings.
