190xt won't lift disc mower
jdodds79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt won't lift disc mower
    Posted: 02 Jun 2016 at 5:27pm
My 190 xt will only lift my 10ft disc mower about 4in, on the 3 pt and the same on the cutter bar. Ive tried turning the relief valve up a little and no help. Have good pressure, just wont lift. Help!!!
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 8:24pm
Check he screen in the sump. It may be clogged.
Other problems could be a malfunctioning flow divider or the pump needs rebuilding.
allis/cattle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis/cattle Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 9:36pm
where is this flow divider???
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 9:43pm
How much pressure are you developing at a remote valve coupler?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 9:49pm
I assume you already checked to make sure you had plenty of hydraulic fluid in the torque tube.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 10:29pm
I have plenty of hydraulic fluid. I havent put a gauge on it yet, but if you crank a line by the pump it has pretty good pressure. Where is the screen in the sump?
screwloose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 1:23am
Under the torque tube. Has a drain plug in the center of it. It's the humdinger that the 2 bigger metal tubes bolt to on both sides of the bottom of the torque tube. You can buy a 5,000 lb. Hydraulic gauge for around $35. And check the pressure at the remotes.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 5:45am
Pretty good pressure is very little information. Dad's old XT gasser had a weak pump to the point it wouldn't lift a round bale of hay. Pump needed to be replaced it was so worn out.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 6:04am
"Pretty good pressure" and "I tried turning up the relief valve a little" ?? Those are really funny statements for a guy who doesn't have a pressure gauge!!! Keep goofing around like that and you may have a hydraulic pump body split wide open. Just because you think the tractor should be able to lift this mower easily, doesn't mean you aren't exceeding the weight capabilities of the 3 pt hitch. Locating the top link in the top hole on the tractor is one way of increasing the hitches lifting power. The bottom hole reduces the lifting power. GET A 3,000 PSI GAUGE AND PLUG INTO A REMOTE OUTLET.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 7:32am
There are two relief valves in the lift section. One for the main lift and the other is for the traction booster. The main relief is the hard one to get at. It's fairly easy to adjust the pressure if you have an accurate gauge.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 8:01am
100 psi is a lot of pressure when you loosen a line, but 100 psi won't lift the lift arms. Like others have said, you don't know the pressure until you put a gauge on it.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 8:10am
Where is the main relief valve located?
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 8:38am
Have you used the tractor to lift/raise the mower/cutter bar before? If you have before then I would say you have developed an issue. If not, a 10ft disc mower is a heavy SOB. You might be asking a bit much of your tractor.
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 8:45am
I lift a 9' New Holland with our 185 fairly easy, our 175 will lift it but the front comes off the ground a bit making it very hard to steer.  So I think he should be able to lift it, if the pump is working correctly.
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 10:32am
Yup! Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 11:04am
Do i need to drain the hydraulic fluid to check the sump screen?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 11:20am
You don't take directions very good. The suction screen isn't your problem. Yes, you have to drain all the hyd oil to clean the screen, which isn't your problem. You might have a pressure problem (and you might not) and that is only verified with a 3,000 psi gauge plugged into a remote outlet and pulling/pushing on a lever to activate the hydraulics. You didn't answer the question as to whether or not you've ever picked this implement up before, or if this is the first time for this tractor and implement. You need 2,200 to 2,400 psi at the gauge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 11:26am
Firts off, if i want directions ill ask my gps. This is the first time with this mower on this tractor. The tractor also will not lift my moco which lifts off of remote. So as of mow it won't work any implement. I dont currently have a gauge, so im trying to check what i can until it arrives.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 11:34am
Ouch. That attitude won't help you much. Dr Allis isn't some Jonny come lately, he's a darn smart guy who is trying to help. Remember the fly & honey deal.
All I can say is good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 11:38am
Drallis very well might be the best source for info on here. I hadnt disrespected any one on here and expect the same in return.
Edited by jdodds79 - 03 Jun 2016 at 11:39am
CrestonM View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 11:49am
No one should ever talk that way to the Dr! He said nothing to disrespect you. He only suggested you do one thing, and you persist on doing another. He's an expert for a reason. He's one of the top 5 smartest guys on here, as far as I'm concerned. Seems he always has an answer to everything related to big machinery, whether it be a One-Ninety not lifting, a 7080 not moving, or a Gleaner L3 with air in the steering lines.
If you so choose to talk that way, I sure wouldn't expect an answer back! JMHO
Edited by CrestonM - 03 Jun 2016 at 11:51am
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 11:52am
All true. However, "You don't take directions very well" sounds pretty insulting, whether meant that way or not. Everybody can be grumpy at times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 12:17pm
If that had been Dr Allis first post then maybe, however just a few posts above that he offered a semi-lengthy explanation and suggestion, which the OP chose to completely ignore, only to come on and ask again after trying something else.
When I had an issue with my 7000 I had a few ideas too, however the second I did as Dr Allis suggested the issue was solved. I'm sure he has other things to do then sit here and repeat the same answers/suggestions time after time.
I'm guessing some of this is just a case of the keyboard not giving the same meaning as a face-to-face conversation.
Edited by Play Farmer - 03 Jun 2016 at 12:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 12:23pm
Oh, I get it. Trust me I get it, it can be extremely frustrating both trying to communicate sometimes, and to have people seemingly outright ignore you, to trying to get through an obvious misunderstanding about intent.
I simply meant, I think the comment by the Dr. is what ticked the guy a bit. Justified or not, intended or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 12:23pm
As I stated, i do not have the gauge currently. I figured I'd go a head and check what i could with what i have. Seemed logical but apparently not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 12:31pm
Hang in there. It get's better. It can be double frustrating to have equipment trouble, especially when you're in a bind and need it, then be hamstrung in communication by the limitations of a keyboard, or worse, a smart phone and a bad auto -correct insertion somewhere. Hang in there, take a step back and breathe, a lot of very good people on here who mean well.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 1:18pm
As stated earlier by others, without a gauge you are playing with fire by adjusting the relief valve at all and could end up splitting the pump. $2,000 buys you a new aftermarket pump and $700 might buy you a well used one. If it's that critical to get going right now you may have to hire or rent.
Edited by Lonn - 03 Jun 2016 at 1:19pm
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 1:42pm
 I don't have a dog in this fight but here is my take.The reason the Dr  gives directions like he does is to eliminate and or isolate the problem. When given advice from him or others that are very competent, they want to exclude or eliminate any other source of problem. They have been down this road many times. Start with what is most like cause and work from there.When you try more things than one at a time ,you are asking for trouble. I  have the same problems with my line of work, I do things for a reason, and inturn expect the desired results. I ain't no genius , and have probably tried their patience too, but and much thankful for their help ans assistance. They have both helped me numerous times. This thread is one of the reasons some with the knowledge to fix your problem, just read and go on. JMHO,  Always willing to learn, Tracy
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 2:52pm
JDodds, Here is the deal from my perspective of being here for 18 years commenting and watching... Doc is a busy man, like said, he has been down this road many times... and should be glad that he is willing to help and give his expertise.  When he asks questions and from the man that has troubles, he needs the answers to help pinpoint the cause.
 Not picking on you singled out, because many times over the years I have seen that happen, somebody asks for help, then the fellow that tries to help asks questions  and then the one needing help disregards answering the questions and makes some other question or statement.  To answer the doc, the least you could have done was to say, "I have a gauge coming" some where in your reply and he would have taken that into consideration and he might not have had the answer he gave.
  My 190XT lifts a 12 ft. moco and has plenty of hydraulics to do it. and the 190 gas will lift a 1327 disbine with the same ease.
  Question is when you are lifting the discbine or the 3pt, and it does not lift, do you hear any reliief valve squeel?
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 2:56pm
175 and 185 can lift more than a 190xt. It is because of the xts have a bad angle on their cylinder to lift arms. On Nebraska test xts are rated less lbs at end of lift arms. That is way the 200 put the cylinder under axle instead of over axle.
