190xt timing |
Post Reply |
steve(oh)
Bronze Level Joined: 12 Sep 2009 Location: ohio Points: 107 |
Posted: 05 Feb 2024 at 11:33am |
I have searched the forum reading on timing. But still having trouble. Rebuilt the engine. Had the pump rebuilt but a good diesel shop. Set my cam to crank dots when I put the engine together.(now I’m questioning if I messed that up). Had the damper rebuilt so I’m hoping it was indexed correct. Anyways go to start it and I get a bunch of smoke. But it won’t fire. Checked my timing. Damper is at 26 BTDC. Valves on one seem correct. When I ran the valves when we first put it together. There was very little adjustment needed. Timing marks in the pump window line up. First question should the timing marks in the pump window be centered? If I divided the window in thirds mine are in the bottom third. Also when I put a welding rod in the injection hole. It seems the piston is going down when my damper says TDC. Not sure if the damper may have been indexed wrong
When your working on something how does it always seem that merphy's law come into affect?
Wide open, Untill you see God. Then Brake |
steve(oh)
Lots of frustration later I got it running. My freshly rebuilt damper was rebuilt wrong. When they rebuilt it, they were only around 25 degrees off on the timing marks. talk about alot of frustration for something that shouldn't of been
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1255 |
Great that you found it. Too bad that someone had to put you thru that.
captaindana
Orange Level Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2444 |
I feel your pain! That’s a terrible deal.
Blue Skies and Tail Winds
Dana |
Fred in Pa
Orange Level Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9189 |
This is why I check for that when putting engines together and taking them apart .With head off using a dial indicator checking top dead center on piston with balancer marks .
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8159 |
Excellent tip Fred!!!
Post Reply | |
