190xt timing
steve(oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(oh) Quote  Post ReplyReply Direct Link To This Post Topic: 190xt timing
    Posted: 05 Feb 2024 at 11:33am
I have searched the forum reading on timing. But still having trouble. Rebuilt the engine. Had the pump rebuilt but a good diesel shop. Set my cam to crank dots when I put the engine together.(now I’m questioning if I messed that up). Had the damper rebuilt so I’m hoping it was indexed correct. Anyways go to start it and I get a bunch of smoke. But it won’t fire. Checked my timing. Damper is at 26 BTDC. Valves on one seem correct. When I ran the valves when we first put it together. There was very little adjustment needed. Timing marks in the pump window line up. First question should the timing marks in the pump window be centered? If I divided the window in thirds mine are in the bottom third. Also when I put a welding rod in the injection hole. It seems the piston is going down when my damper says TDC. Not sure if the damper may have been indexed wrong
When your working on something how does it always seem that merphy's law come into affect?
Wide open, Untill you see God. Then Brake
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(oh) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2024 at 7:16pm
Lots of frustration later I got it running. My freshly rebuilt damper was rebuilt wrong. When they rebuilt it, they were only around 25 degrees off on the timing marks.  talk about alot of frustration for something that shouldn't of beenAngry
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2024 at 8:19pm
Great that you found it. Too bad that someone had to put you thru that.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2024 at 5:30am
I feel your pain! That’s a terrible deal.
Blue Skies and Tail Winds
                          Dana
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2024 at 8:42am
This is why I check for that when putting engines together and taking them apart .With head off using a dial indicator checking top dead center on piston with balancer marks .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2024 at 9:16am
Excellent tip Fred!!!
