190XT Starter |
Gary (sw Wis.)
Silver Level Access
Joined: 12 Sep 2009 Location: S.W. Wis. Points: 223 |
Topic: 190XT StarterPosted: 14 Jan 2023 at 4:10pm |
Is there a trick to getting the starter out without taking the fuel line apart?
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2492 |
Posted: 14 Jan 2023 at 6:33pm |
Shut the fuel off at both of the sediment bowls. Take the inlet line loose at the primer pump and also loosen the line at the fuel filter base that comes from the primer. Remove the one bolt that's secures the primer assembly and just set the whole thing aside. Put the bolt back in if it leaks a little antifreeze. Plenty of room then for the starter removal.
Gary (sw Wis.)
Silver Level Access
Posted: 15 Jan 2023 at 7:46am |
Thanks Lynn, That what I thought, I was hoping to avoid removing thr primer.
NDBirdman
Posted: 15 Jan 2023 at 9:20pm |
I had to remove my primer to remove the starter. |
