190XT serial numbers
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT serial numbers
    Posted: 25 Aug 2020 at 10:12pm
why do some some of the diesels say XTD and other DXT?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 6:57am
I've never noticed that difference before.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 12:45pm
only way I noticed was I had both my tractors side by side and checked the serials and one is a XTD and the other is a DXT
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 9:08pm
Must have been dependent on however the guy doing the stamping felt it should be. Unless there were some straight 190's converted to XT's before they left the factory. Turbo and oil cooler would be the only major changes needed as far as I know.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 9:09pm
Unless the XT had a separate serial sequence than a straight 190 so then I'd go back to the thought that it was at the discretion of whoever was doing the stamping.
Wink
I am a Russian Bot
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2020 at 12:24pm
In this instance, it would have got a completely different engine. There's so many little things different between a 2800 and a 2900. I cannot see the factory ever swapping engine parts, but they may have swapped a complete engine, since they were a separate component from Harvey. Just my opinion though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2020 at 6:12pm
the kicker is they both have d2900s only thing differnt was the turbos between the two tractors one had the solar type other had a to4
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2020 at 8:49pm
What year are they?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2020 at 8:53pm
I can see someone picking up the D stamp first, striking it, realized his mistake, and said well its a diesel, and its a XT. DXT
Just saying its possible
