190xt PTO
WW190xt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WW190xt Quote  Post ReplyReply Direct Link To This Post Topic: 190xt PTO
    Posted: 11 Oct 2020 at 7:10am
HI..I am new to this site.I really enjoy all the information here.This summer I picked up a 170 Diesel and 190xt. I plan on going through them this winter.They both are in pretty decent shape.The previous owner of the 190 said the PTO would slip under a heavy load.just wondering where to look first. He had engine and transmission rebuilt
Thanks
Will
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 7:36am
Manual pto or hydraulically actuated pto?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote WW190xt Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 7:42am
Hydraulic
Joe(TX) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 7:58am
A worn engine clutch can cause the pto to slip.
Otherwise it could be from low hydraulic pressure to the pto clutch or worn discs in the clutch.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 12:51pm
Start by making sure the clutch pedal has at least 2 inches of freeplay in it. Check pressures on the Power Director/PTO clutch circuit and make them correct if they are not. Test the PTO clutch performance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WW190xt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 4:16am
Thank You for the information!
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 8:14am
my 190xt pto stops under heavy load. I know it is the foot clutch causing it because i took off with a heavy manure spreader and clutch slipped for a bit. I have oil leaking out the bottom of clutch housing from transmission input shaft prolly getting on the clutch.
www.awtractor.com
A&W TRACTOR 920-598-1287
This page was generated in 0.111 seconds.
