190XT PD |
NDBirdman
Topic: 190XT PDPosted: 04 May 2020 at 10:43am |
Does the 190XT power divider share tractor hydraulics or is it separate? If separate, where is that drain plug/fill and how much/type fluid? The power divider works good between lo/hi but does not engage... hard, more like easily slips into high. I drained the hydraulic fluid, put a new filter on and filled. Have not operated it since doing so as I'm awaiting a water pump.
Posted: 04 May 2020 at 12:47pm |
Hydraulic system is the oil to apply and lube the Power Director clutch. Two drain plugs. Takes about 5+ gallons of oil.
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 04 May 2020 at 5:51pm |
Both drain plugs are on the torque tube.
