190xt injection lines
steve(oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(oh) Quote  Post ReplyReply Direct Link To This Post Topic: 190xt injection lines
    Posted: 05 Dec 2023 at 5:24pm
Has anyone found injection lines aftermarket? Or just go through AGCO? I have #6 that is getting rubbed real bad and kinda wanted to replace it along with the rubber hold down for the lines. Not having any luck finding them from aftermarket places
When your working on something how does it always seem that merphy's law come into affect?
Wide open, Untill you see God. Then Brake
DPKII View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DPKII Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 8:08am
Steve,
If you do not have any luck finding new injector lines you may look into brazing the one you have.  I have never attempted it but I know that Dad brazed a couple of lines on grandpa's D17s that had rubbed through and were leaking.  They ran with the brazed lines for many many years.  Since yours is not leaking yet, it should just be a matter of filling in the rubbed spot with braze to reinforce.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 8:58am
What serial range engine you have?
ryan
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 9:05am
One thing about brazing them, the bronze will actually be more wear resistant than the steel line itself. If you can braze or know someone that can, that's the path I'd follow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 9:20am
It it was me, I'd contact someplace like Fair Valley Performance to see if they already have a pattern. As many people that are running 301 engines in pullers, someplace has prebent ones.  If not, I'd send my old set to them to have them matched.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(oh) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 10:54am
I’ll have to look. It’s an earlier 190xt.
I thought about brazing. Just wasn’t hoping someone out there had found something I had not ran across
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 3:40pm
You will not find something like that aftermarket.  Someone here might have some good used ones available,
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 5:12pm
If it's not worn through why not just bend it so that it isn't touching another. Very unlikely it will blow out as is. My point is why braze it if you can bend it out of the way?
