190XT inj pump
Gatordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatordoc Quote  Post ReplyReply Direct Link To This Post Topic: 190XT inj pump
    Posted: 29 Jun 2010 at 8:28pm
How hard is it to change the seals on the throttle shaft and fuel stop shaft? I have got the pump off  TIA Warren
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 10:18pm
Remove pump cover, remove the shutoff tab from shaft and pull the shutoff shaft out. The throttle shaft is a little harder. Remove the allen head screw from the end of throttle shaft to give clearance for shaft to clear the block. By turning the shaft to the right place they will usually come out.   MACK
