Print Page | Close Window
190XT inj pump
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=14513
Printed Date: 03 Feb 2025 at 2:13am
Topic: 190XT inj pump
Posted By: Gatordoc
Subject: 190XT inj pump
Date Posted: 29 Jun 2010 at 8:28pm
How hard is it to change the seals on the throttle shaft and fuel stop shaft? I have got the pump off  TIA Warren
Posted By: MACK
Date Posted: 29 Jun 2010 at 10:18pm
Remove pump cover, remove the shutoff tab from shaft and pull the shutoff shaft out. The throttle shaft is a little harder. Remove the allen head screw from the end of throttle shaft to give clearance for shaft to clear the block. By turning the shaft to the right place they will usually come out.   MACK
