190xt hydraulic fluid leak around steering
Allis Eli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Eli Quote  Post ReplyReply Direct Link To This Post Topic: 190xt hydraulic fluid leak around steering
    Posted: 13 Dec 2024 at 9:41am
Hey Everyone, Had a question on my ac 190xt. I was feeding a hay bale and the tractor suddenly started pushing hydraulic fluid out of the steering column. My 190xt has a cab and in order to remove the hood you would need to remove the cab. How hard of a fix is it to stop the leak?. Is it just a Oring or?
Thanks
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2024 at 5:11pm
We had a 190xt. Started it up after lunchone day and fluid started pouring out of the steering collumn. Got the mechanic out to it started it wasnt doing it any more. Never did that again. Go figure
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 6:31am
Quad seal on the steering orbitrol needs replacing. Hood has to come off I think I could do one without disconnecting the four hydraulic hoses from it. Only remove the end cap and replace the quad seal and anything else right there. Do NOT disassemble any further than the end cap plate. Seal kit from AGCO and some parts you won't use.
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 8:03am
Not sure what kind of cab you have but I had a Laporte cab and I took off the top steering cover, then I took off the exhaust stack and the air pre-filter stack, took off the nose grill, and was able to remove the hood without removing the cab or even loosening it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 8:38am
I've never had to remove a cab either. Sometimes the hood can be slid forward a couple of inches and drop down at the rear and then up and forward with the front of the hood. Exhaust pipe and instrument panel get removed first.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 12:13pm
The last one that I did,I was able to get the 4 bolts out that hold the orbitrol to the steering column. I then swung the orbitrol down and out the right hand side. I obviously had to remove the right side panel,but I did leave all of the hoses attached.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 1:10pm
Like Lynn said that is how I do them
jdeere562 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdeere562 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 2:04pm
Very likely a steering hose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 2:16pm
A steering hose doesn't pump oil up thru the steering column onto your lap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdeere562 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 2:28pm
Folks are often very vague about leaks. Just pointing at an area to check.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Eli Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2024 at 6:32pm
thanks for the advice everyone, I will order and install the seal
This page was generated in 1.941 seconds.
