|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| 190XT Gas |
| Post Reply   |
| 190XTLP   Bronze Level   Joined: 06 Oct 2009 Location: Jerseyville il. Points: 51 |  Post Options  Thanks(0)  Quote  Reply  Topic: 190XT  Gas Posted: 30 Jul 2018 at 12:44pm |
   Engine runs perfect except for a bad governor hunt at mid speed Has been adjusted per service book...bad spring? Any ideas? | |
     WD45G,WD45D.190XTD,190XTLP D19LP,WC unstyled,WF unstyled WC styled,220 | |
| john(MI)   Orange Level     Joined: 12 Sep 2009 Location: SE MI Points: 9262 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Jul 2018 at 1:12pm |
   I have never seen a 190's governor setup but on the 45 and D14 I have, the linkage was the problem.  Especially across the front of the engine.  I sprayed the linkage system with PB Blaster a couple times, then lubed with a silicon spray lube.  Hope that helps, good luck. | |
| SteveMaskey(MO)   Orange Level     Joined: 11 Sep 2009 Location: Wellsville, MO Points: 625 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Jul 2018 at 7:16pm |
   Make sure the throttle shaft ear where the linkage hooks up on the carb has not come loose. I have had that happen twice and will make the governor hunt as you describe.
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
