190xt brakes
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Topic: 190xt brakes
    Posted: 26 Nov 2023 at 5:18pm
The adjuster bolts (3/4 hex) on my XT  cant be tightened like they are bottomed out. What needs to be done to lessen the free travel on the pedals?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2023 at 9:45pm
Sounds like the pads are bottomed out? Have you removed the cover to inspect them? Wear a mask, nasty stuff in there. I replaced mine several years ago due to that issue. Cleaned the balls and ramps also. I have great brakes now. They are external!!! So much easier to work on.
Edited by AC720Man - 26 Nov 2023 at 9:47pm
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2023 at 11:14am
OK, should I plan to replace the disks shaped lining and the bands at the same time?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2023 at 12:25pm
You can shorten the brake rods at the front if you want, but your brake linings are probably about shot and you don't want to have a metal to metal situation. $$$$$$.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2023 at 12:30pm
Thanks for the input. Ill get it torn down and looked over. I'll put it back together best I can so it will stop good for as long time as possible.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2023 at 12:32pm
RW...I sent you a message thru the forum here...Rick
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2023 at 2:50pm
You will not know for sure until you open things up and take a look.
