190n hydraulic fluid
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: 190n hydraulic fluid
    Posted: 15 Oct 2011 at 9:04pm
i need to replace the hydraulic fluid and filter in my 190 diesel. i have used cenex quik lift and farm oyl hydraulic fluid in most every thing in the past but to lower cost i have access to a  supply of o'reilly's  303 hydraulic fluid.  Can i use it and still feel confident  it will do the job ?   thanks for your help. tractorman.
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 9:30pm
I am not an expert on this but I say NO!!The fluid in the 190 has to be hydraulic and transmission formula (known as hy-tran).The trans and rearend gears run in this oil also.I don't think the 303 will have the load capacity for the gears.
   If you don't want to ruin parts the oil should be listed as meeting AGCO 821 specs.Wal-Mart even carries this.
Edited by Steve M C/IL - 15 Oct 2011 at 9:32pm
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 11:34am
Generic, Universal Tractor Fluid. It meets MOST mfg specs. This is a 40 year old tractor, modern oils are WAY better than the oils of yesteryear.
CT
2014 LS P7010C, 1962 Farmall 504 Diesel (1st tractor) w/ 2008 Koyker 220 FEL, 1968 Allis Chalmers 180 Diesel, Komatsu PC38UU-2 Excavator, Various attachments for all!
This page was generated in 0.091 seconds.
