190 xt second set of hydraulic outlets |
ribsplitter ![]() Bronze Level ![]() Joined: 10 Sep 2010 Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Sep 2010 at 12:39am |
buying a 190xt with one pair of hydralic outlets, has two hydralic controls how do i add a second set of outlets to use a 350 dual loader?
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8657 |
I would guess that if the lever is there for a second set of coupler's, the valve and everything should be there also. Look under the operator's platform on the right hand side, directly under the levers, and you'll see where the control linkage from the levers connects to the valve stack, then see if the second lever is hooked onto a section of the valve stack. If there is a second valve stack there, you should be able to copy the hydraulic lines from the one set that is there, to put the second set on. P.S. If your tractor has a 3 PT on it, there'll be a valve stack section for it as well. I hope this somewhat helps Darrel
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Darrel has it right, and if the valve is there I would think all you would have to do is remove the plugs and plumb hoses in.
ALLIS EXPRESS!
This year: |
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
yeah...i bought a 180D with only one set hyd's, the plumbing was there for another set, i just took the plugs out and screwed a nipple with hyd couplers on.....and they worked!!
