190 transmission rear end oil level
brad7066 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad7066 Quote  Post ReplyReply Direct Link To This Post Topic: 190 transmission rear end oil level
    Posted: 13 Mar 2022 at 7:42pm
how much over the full line should i be running my 190. it has a coupler in it with no hydraulics
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2022 at 9:17am
For pulling?? the higher the better, to flood the differential gears. Use light weight (HyGuard/HyTran/821XL/Permatran) oil, not 80/90 wt.  Oil level can be as high as half-way submerging the top shaft in the transmission and then that will have the differential half submerged too.  Needling the differential is a good thing.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2022 at 1:41pm
as to the front end - if you have no PD clutch - many take out the torque housing gears and put in sealed bearings so one needs no oil - IF you still have the torque housing gears we put oil jugs in bottom of center housing and foam to cut down on amount of oil needed -but you have to keep those cone/cup needle brgs in the front housing wet... about normal on RH dipstick...
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad7066 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2022 at 2:09pm
differential gears have been needled was told by them to run mystik synthetic.
goomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2022 at 10:16pm
I drilled and taped a drain plug on the circle plate on side of torque housing just about even with clutch main shaft. I keep filling until oil comes out. Takes a bit of time to get oil there.
