190 top link
Boman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boman Quote  Post ReplyReply Direct Link To This Post Topic: 190 top link
    Posted: 02 Sep 2025 at 10:56am
Does anyone know this, I think the 190 allis used a shorter cat 2 top link does anyone know what the shortest and longest measurements are?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 11:32am
Factory 3-point hitch ?? or add-on ??
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 12:17pm
My seriesI still has the original top link, but I won't be near it until the weekend. I do know it makes a nice place for wasps to build a nest. On my seriesIII and 7000 I use universal replacements, I think mine came from All States but you can buy them at most implement dealers and a lot of the farm supply stores. As far as I know they aren't much different than anything else.
Ted
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 3:52pm
Only 1 top link used as per the AGCO parts book.  The 190 uses the same top link as a D17 series 4, 170, 175, 180, 185 and others.
I have one I can sell if anyone needs one.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 4:08pm
I need one
Donald Matthews
910 824 8856
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 5:15pm
Could you measure it when turned into shortest position please
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 5:17pm
Mine is oem three point
When I use aftermarket one it does not go short enough for my mounted field cultivator but on my ford it works fine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 5:58pm
Ted
Ted it would be great if you could measure it
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 6:20pm
Unfortunately I don't live with my tractors, I plan to be there Saturday. If I get an opportunity before then I will measure it.
Ted
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 9:31pm
190 turned in is 20 inches center of hole to center.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 16 minutes ago at 9:29pm
I measured mine today, didn't turn it in because I didn't want to disturb the residents(wasps). Measuring what it is now and amount of thread sticking out I think it will go to 21" center to center. I also measured the aftermarket that I use, it also goes to 21" center to center. I took a picture of one my brother shortened, I think the last time it was used was on a JD 70 with the aftermarket hitch. Not sure if it was shortened for the tractor or for the disc.
Ted
Edited by TedN - 2 hours 6 minutes ago at 9:39pm
