190 top link |
Boman ![]() Bronze Level ![]() Joined: 31 Aug 2025 Location: Minnesota Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: 8 hours 42 minutes ago at 10:56am |
Does anyone know this, I think the 190 allis used a shorter cat 2 top link does anyone know what the shortest and longest measurements are?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21885 |
Factory 3-point hitch ?? or add-on ??
TedN ![]() Bronze Level ![]() Joined: 30 Apr 2025 Location: Central WA Points: 84 |
My seriesI still has the original top link, but I won't be near it until the weekend. I do know it makes a nice place for wasps to build a nest. On my seriesIII and 7000 I use universal replacements, I think mine came from All States but you can buy them at most implement dealers and a lot of the farm supply stores. As far as I know they aren't much different than anything else.
Ted |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7501 |
Only 1 top link used as per the AGCO parts book. The 190 uses the same top link as a D17 series 4, 170, 175, 180, 185 and others. I have one I can sell if anyone needs one.
8070nc ![]() Orange Level Access ![]() Joined: 21 Mar 2019 Location: North Carolina Points: 618 |
I need one
Donald Matthews 910 824 8856 |
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
Could you measure it when turned into shortest position please
Mine is oem three point When I use aftermarket one it does not go short enough for my mounted field cultivator but on my ford it works fine |
Ted it would be great if you could measure it |
Unfortunately I don't live with my tractors, I plan to be there Saturday. If I get an opportunity before then I will measure it.
Ted |
