190 straight shaft couple question
brad durst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad durst Quote  Post ReplyReply Direct Link To This Post Topic: 190 straight shaft couple question
    Posted: 10 Nov 2019 at 7:16pm
i have heard that i can couple and delete the power director with a coupler out of a 7000 if so what coupler is it. i have also been told that i can made a manual shift coupler out of parts out of a d17 if so what parts do i need
ACman75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 1:28pm
For the direct coupler you can use a coupler from180,185,200 dual speed PTO
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad durst Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 4:38pm
is that in the back where you flip the shaft for 1000 to 540 or is it locates somewhere else on the tractor.
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 5:58pm
It’s located in the TQ housings if I remember. below the PD. Part number 70230321
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad durst Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 7:59pm
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad durst Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 7:45pm
will that give me the hi side or low side
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2019 at 9:22pm
4 high side gears. It connects the input shaft of trans and clutch shaft of motor together. Direct drive. You remove power director all together
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2019 at 9:32pm
