190 parking brake latch problem |
Post Reply |
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 8183 |
Posted: 29 Jul 2010 at 6:26pm |
I was messing with my 1964 190 AC the other day and the parking brake latch is giving me a fit ; when you flip it back and step on the brake for it to release , it wont release , it just gets tighter, if you flip it back + forth a few times it may work and may not ; it seemed to have some play on the shaft , so I shimmed it , didnt help, its really aggrivating , anyone have this happen ?
Gordon,scia
Bronze Level Joined: 15 Sep 2009 Points: 11 |
We had a similar thing happen to our One-Ninety. Turned out that one of the hydraulic lines was interfering with the linkage. We replaced that line with a new one that had a ninety degree fitting (or something like that, IIRC) and it corrected the problem. Look up under the hood at the back and see if anything is in the way of the lock mechanism. Hope this helps!
allisorange
Silver Level Joined: 27 Mar 2010 Location: perkins, michig Points: 381 |
If the latch is in wrong it will act that way.
John C
DanWi
Orange Level Access Joined: 18 Sep 2009 Location: wttn Points: 1860 |
Is the roll pin that holds the lever on the shaft broke?
Orange Level Access Joined: 12 Sep 2009 Points: 20970 |
Lube/oil the rectangular block that fits on the shaft....they get dry and sticky.
Post Reply | |
