185 |
Mallettfarms
Topic: 185Posted: 28 Sep 2024 at 1:27pm |
I’ve got an injector line that leaks but can’t find a replacement for it and unsure if other models will fit the 185.
DougG
Posted: 28 Sep 2024 at 7:16pm |
Wheres it leaking ? Rubbed a hole in it ? Theres thousands used out there , just make sure you get the right one for that cylinder
Mallettfarms
Posted: 28 Sep 2024 at 8:01pm |
Yea it has rubbed a small hole it on cylinder 1 I can’t seem to find them at all
Posted: 28 Sep 2024 at 8:13pm |
Usually a pretty easy brazing job. I've fixed a dozen or so in the last 4 decades.
orangereborn
Posted: 29 Sep 2024 at 9:57am |
I have a parts 180 and a couple of power units if they would be the same. I know there are some lines left on them.. I have braised them in the past.... thanks.. Dale
Edited by orangereborn - 29 Sep 2024 at 9:59am |
Mikez
Posted: 29 Sep 2024 at 7:30pm |
Have nos line 4020109 fitting prior to SN/2D-26977
Mallettfarms
Posted: 29 Sep 2024 at 7:32pm |
I’ll have to go check and see what the serial number is I know it’s a 1975
Posted: 29 Sep 2024 at 8:51pm |
Engine s/n not chassis.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5124 |
Posted: 30 Sep 2024 at 8:15am |
guessing sn change is for american bosch injectors? The injection line should go in the top of the injector on a bosch injector. Not many of those made.
Posted: 30 Sep 2024 at 8:58am |
They had at least two different line sets over the years for the A-C injectors. The early lines were different because the injection pump had that aluminum spacer between it and the engines front plate. Later engines the pump sat 3/8" farther forward so the lines were changed to accommodate that new location. Then came the Bosch injector lines.
injpumpEd
Posted: 30 Sep 2024 at 9:42am |
Thought all 185's were new enough to not have the long shaft, and adapter spacer. Thinking also, only very early 180's had the long shaft. The 180/185/190 lines are different than a turbo 190XT though, due to the oil cooler.
Posted: 30 Sep 2024 at 10:24am |
AGCO parts books isn't very helpful. They have the 180 and 185 lumped together and just show the change prior to and effective at engine s/n 2D-26977. Doesn't specify which model tractor.
Mikez
Posted: 30 Sep 2024 at 7:30pm |
I just looked in numerical book and says 4020109 fits 180,190
