185 power steering |
WLHD21 ![]() Bronze Level ![]() Joined: 06 Feb 2019 Location: Iowa Points: 155 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Aug 2020 at 6:52am |
Will a Char-Linn power steering control pump from a 7040 work on a 185? All State Ag parts shows them as two different types. They look identical on the outside.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22087 |
It might work, but not correctly. A 170-175-180-185-190-190XT-200-7000 will all fit yours. Surely one of those can be found.
Thanks I will have to rebuild the 185 one, the 7040 one I had on the shelf works fine to the right but turns all the way left with a slight turn of the wheel.
That's what I would expect.
If it's leaking at the steering wheel end, replace the quad seal, dust seal and Oring. DO NOT disassemble the whole unit !!!
Perfect advice thanks!
