185 power steering
WLHD21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WLHD21 Quote  Post ReplyReply Direct Link To This Post Topic: 185 power steering
    Posted: 10 Aug 2020 at 6:52am
Will a Char-Linn power steering control pump from a 7040 work on a 185? All State Ag parts shows them as two different types. They look identical on the outside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 7:11am
It might work, but not correctly. A 170-175-180-185-190-190XT-200-7000 will all fit yours. Surely one of those can be found.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WLHD21 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 7:52am
Thanks I will have to rebuild the 185 one, the 7040 one I had on the shelf works fine to the right but turns all the way left with a slight turn of the wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 8:01am
That's what I would expect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 9:04am
If it's leaking at the steering wheel end, replace the quad seal, dust seal and Oring. DO NOT disassemble the whole unit !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote WLHD21 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 9:52am
Perfect advice thanks!
This page was generated in 0.067 seconds.
