185 lift arms stuck in up position
TimZ(TX) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Topic: 185 lift arms stuck in up position
    Posted: 20 Jul 2010 at 11:34am
I've seen this post several times and can't remember the cure.    Is it the traction boost valve that is stuck and if so what is the fix?   The arms go down after the tractor is turned off.   There is a whining sound from the spool when you speed the motor up.   I will pay better attention from now on.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2010 at 11:47am
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2010 at 11:17pm
Following Skyhigh's link, refer to the second picture where there is a bolt with 2 nuts - 1 is shiny.  If you remove that bolt, there is a bushing in there that has rusted up.  Take it out, clean it up, and coat it with anti seize, and you will be good for a long time.  Problem solved.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2010 at 9:49am
Thanks  I'll get after it this weekend.
Edited by TimZ(TX) - 21 Jul 2010 at 9:50am
