185 final drive adjustment
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: 185 final drive adjustment
    Posted: 05 Jun 2018 at 1:22pm
How do you go about tightening up the shaft that your wheel is bolted to on the final drive on a 185?
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 2:06pm
Never done a 185, but the other AC tractors have shims on the end of the shaft. Take the center plug out of the final drive and take out the bolt that goes into the wheel shaft. Should be shims under the washer. Remove the appropriate amount and then re-install the bolt and cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 2:30pm
That's what it looked like under the cap. I was changing the fluid in the pans and have some movement when I grab the wheel at 12:00 and push and pull.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 9:54pm
I would guess one of the two bearings are flailing.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 10:48pm
Agree with MACK.Unless someone has fiddled with it prior,it would have been correct from factory so looseness indicates bearing loosing material.Those are not that hard to work over.Once you remove cap with shims,you can drive axle out to inspect brgs.Some fit tighter than others.Bull gear will drop out bottom when axle is removed.It only fits one way because of hub. My advice is from dealing with a WD45 but they are the "same".
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 8:20pm
Two shims and it snugged it right up.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 8:24pm
Good job Mark.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 8:31pm
Thanks Burgie, I did it like you said, take one out try it.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 7:18am
Probably still a bad bearing that will be out after a while. I've seen two 185 axles break from a heated bearing. (I'm assuming heat caused it) I repaired the one 185 myself while working at the Allis dealership. Have never seen any other Allis axle ever break but these two different 185s in my area did. Oh, and a 7060 with long axles and running with a chisel plow and a flat inside dual.
Edited by Lonn - 13 Jun 2018 at 7:22am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 8:27am
Dad's 49 WD broke both axles within 5yrs of each other in mid 60's.New ones had more meat where they broke.
