180D oil leak
Fellenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Topic: 180D oil leak
    Posted: 23 May 2011 at 10:35am
I'm troubleshooting an engine oil leak on our 180 diesel that has recently begun to leak at a fast enough rate that we're losing a few quarts of oil in just a few hours.
I've removed the tin and pressure washed the engine to get the oil off. Now with it clean I can see by running the engine that the leak is beginning between the head gasket at the front of the block and the water pump.
I've never torn into this engine past the valve cover so I'm flying a little blind, would there be a reason it could be leaking oil around the front of the head gasket or is the gasket between the block and the water pump more suspect?
Thanks for any advice, hopefully someone knows better than I do where the oil runs inside this engine so I won't need to tear into two areas looking for a leak.
Thanks,
Erik
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 11:45am
Valve cover gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 11:50am
It doesn't seem to be the valve cover gasket, although I have had leaks there before.
There is no oil dripping down the front of the head.
It's definitely coming from head gasket height on the engine.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 9:45pm
Valve cover leaks on right side and fan pulles oil along headgasket to front to where you see it.   MACK
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 10:52pm
Follow Doc and Mack's advice.They have delt with AC's since Adam.
